It is currently Fri Aug 15, 2025 2:12 am
 Post subject: Band saw blade welder
PostPosted: Sun Nov 23, 2014 5:18 am
First name: Tom
Last Name: West
State: Nova Scotia
I wonder if anyone has ever made a band saw blade welder? Not a jig to hold the blade for brazing but rather a spot welder.
Tom
PostPosted: Sun Nov 23, 2014 8:15 am
Some of the larger metal cutting bandsaws have them built into the saw.
PostPosted: Sun Nov 23, 2014 10:05 am
First name: Tom
Last Name: West
State: Nova Scotia
Clay: Worked as a machinist and all our saws had welders. It seems to me that it would not be too difficult to come up with something that would work. The electronics are beyond me so hoping someone has made one.
Tom
PostPosted: Sun Nov 23, 2014 3:07 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
A good discussion: http://bbs.homeshopmachinist.net/thread ... ade-welder
David Malicky
PostPosted: Sun Nov 23, 2014 4:08 pm
First name: Tom
Last Name: West
State: Nova Scotia
David: Thanks, that was the flavor of what I was looking for, a bit surprised there is not someone here who has done this.
Tom
PostPosted: Sun Nov 23, 2014 10:23 pm
I believe Lee Valley has (or had) a jig and 'silver solder' setup to repair bandsaw blades that was used with a propane torch
Brent
PostPosted: Sun Nov 23, 2014 10:38 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Brent
They still have it. http://www.leevalley.com/en/wood/page.a ... 1036,41048
Alex
PostPosted: Mon Nov 24, 2014 3:34 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
The silver solder works, but your bandsaw wheel must be at least 14" because I found if the wheel diameter is too small, a brazed joint may not hold up well. It also takes a few tries to get the braze right... right temperature, right annealing, right angle, etc.
So many ways for things to go wrong here... one bad weld and the blade is toast. Often when the blade breaks under tension it also kinks it badly
Typhoon Guitars
Users browsing this forum: Colin North and 16 guests
